IDevices
vesnice8
IDevices
by vesnice8 » Tue Oct 08, 2013 8:55 am
Hello and good day
As I saw, the quality on Ipad is really horrible and not better to 1.8. (Pardon me for that)
I know it's a beta Version. But, do modify this for future version?
Or, is there any possibility to change by myself?
Have a nice day and best regards
Likes: 80 posts
Liked in: 182 posts
Re: IDevices
by benji33 » Tue Oct 08, 2013 9:06 am
vesnice8 wrote:As I saw, the quality on Ipad is really horrible and not better to 1.8. (Pardon me for that)
We are currently waiting to integrate multi-res into HTML5 export. So when applied the quality will be the same as the Flash multi-res export. But some features must be fixed before this integration.
So at this time HTML5 exports are blurry.
vesnice8 wrote:Or, is there any possibility to change by myself?
You can try to use Krpano tiles instead Panotour Pro 2 tiles if you prefer.
scoopz
Re: IDevices
by scoopz » Tue Oct 08, 2013 9:28 am
Will HTML5 Multi-res be included in a future update as a native program feature or will it be a plugin or an at cost feature?
I've been playing with gigapixel images in HTLM5 multi-res from krpano and it works brilliantly, fast and smooth, on iOS devices and can't wait for that to be integrated into PTP2.
Test System Spec: 15" Retina MacBook Pro, 2.7GHz i7, 16GB RAM, 768GB SSD, OS X Yosemite
Likes: 13 posts
Liked in: 112 posts
Re: IDevices
by bdd » Tue Oct 08, 2013 9:50 am
scoopz wrote:Will HTML5 Multi-res be included in a future update as a native program feature or will it be a plugin or an at cost feature?
PanotourPro always use the last stable version of krpano player.
The 1.17 version of krpano is a beta version. It is time bombed. So every tour created with it should be updated with newer version of the player after the time bomb expires.
As soon as the 1.17 version of this player is officially released, Panotour Pro will embed it.
This "upgrade" will be free.
If you already want to use the HTML5 multi-resolution player, you can use the update tools of krpano, to change the 1.16.8 player by the 1.17 one.
