Misleading "size" attributes
jschrader
Liked in: 3 posts
by jschrader » Mon Oct 07, 2013 4:01 pm
If one places a picture with the image zone plugin one has to specify the width and heigh of the image.
At least that is waht I though because it turned out that in fact one hasn't.
If you leave the fields to the default value of zero the image displays in the orginal size.
Which is odd.
a. because a value of "0" implies that one has to specify a size
b. because a determined size of 0 x 0 pixels while showing the original filesize is utterly wrong
I suggest you eizer set the default value for the size to something like "original" or levae the fields blank and make sure that size values only matter if one wants it to be other than the original.
Re: Misleading "size" attributes
by mediavets » Mon Oct 07, 2013 6:30 pm
jschrader wrote:If one places a picture with the image zone plugin one has to specify the width and heigh of the image.
Which is odd.
Perhaps, but once you know how it works is it an issue.
And there is another 'trick' this offers as currently implemented - if you enter one value but leave the other bv at '0' then the image will scale but maintain its aspect ratio, this is really useful I think.
jschrader
Liked in: 3 posts
by jschrader » Mon Oct 07, 2013 8:16 pm
Why should people first have to find out by try and error that they are mislead, just because someone was too lazy or too stupid to get it right just from the beginning?
And how many "tricks" does one have to learn to make PTP into what it could easily be without any learning curve?
by mediavets » Mon Oct 07, 2013 8:21 pm
jschrader wrote:Why should people first have to find out by try and error that they are mislead, just because someone was too lazy or too stupid to get it right just from the beginning?
IIRC it was the same in PTP 1.8.
All software has a learning curve.
Likes: 80 posts
Liked in: 182 posts
by benji33 » Tue Oct 08, 2013 8:43 am
Yep. it have been reported and an "auto" value should appears one day for default size. So "0" will be a true zero value.
