PNGs and Alpha
jschrader
Liked in: 3 posts
PNGs and Alpha
by jschrader » Mon Oct 07, 2013 3:44 pm
Like in Krpano it should be possible to add an alpha value to a PNG that is for example used as a picture, logo, or whatever in the Image zone.
Re: PNGs and Alpha
by klausesser » Mon Oct 07, 2013 3:54 pm
jschrader wrote:Like in Krpano it should be possible to add an alpha value to a PNG that is for example used as a picture, logo, or whatever in the Image zone.
Hey Jürgen!
i have the initial sphlashscreen as a .png with Alpha here:
http://www.360impressions.de/Wandelhalle ("Start")
http://www.360impressions.de/KBogen413 (Logo)
So i guess it must work using png/Alphas.
best to you, Klaus
Re: PNGs and Alpha
by mediavets » Mon Oct 07, 2013 6:23 pm
Do you find that PTP does not honour transparency in a PNG file?
jschrader
Liked in: 3 posts
Re: PNGs and Alpha
by jschrader » Mon Oct 07, 2013 8:23 pm
What I'm talking about is to set the transparency level of a PNG from within PTP!
In krpano it's a single alpha parameter and it doesn't occur to me why that isn't used in PTP as well, as it allows the designer to easily tweak the appearance of a tour.
PNGs with predefined alpha so far worked for me, but of course I haven't tested all possible options and combinations.
I leave this to all the other people who, like me, happily paid for an unfinished software *evilgrin*.
Re: PNGs and Alpha
by mediavets » Mon Oct 07, 2013 8:30 pm
jschrader wrote:What I'm talking about is to set the transparency level of a PNG from within PTP!
That has never been offered in PT/PTP. You could/should propose it as a feature request.
