PTP 2 beta 1 extends behind Win 8 taskbar ....
by mediavets » Mon Oct 07, 2013 12:16 pm
PTP 2.0 beta 1 ... Windows 8 pro ... 64-bit versions
The PTP 2.0 beta 1 display extends behind the task bar on my Windows 8 Pro system, also running Start 8, which partially obscures the Build progress bar.
Is this intended?
Re: PTP 2 beta 1 extends behind Win 8 taskbar ....
by gkaefer » Mon Oct 07, 2013 6:53 pm
... in your case: yes - because you decided to do so.
Explanation: in your screenshot top left I can see an Firefox window behind the ptp2 Windows. this leads me to think you did not use the fullscreenoption on top right window middle button. enlarge to fullsize and the bottom window Frame will no longer stick behinde Windows 8 taskbar.
as in every Windows Version since min. 5 years you can move the window partly out of the Screen by moving it to left, right and bottom...
2013-10-07 19_52_16-.png (381.27 KiB) Viewed 572 times
by mediavets » Mon Oct 07, 2013 8:17 pm
gkaefer wrote:... in your case: yes - because you decided to do so.
Doh!....my only 'excuse' is that Widows 8 is very new for me..thanks for spotting my mistake.
