Very weird color issue
AndrewRomer
by AndrewRomer » Sun Oct 06, 2013 10:08 pm
Take a look - A quick walkthrough of what I did.
1.Opened a Pano in PTP 1.8 and exported cube faces as .psd
2.Edited Nadir and Zenith - Saved
3.Installed the new beta of 2.0
4.Imported all 6 faces into 2.0
5.Quick check and everything looked good when it asked if they were the correct orrientation.
6. See Below.....
Can't really figure this out - About to try to restart PTP 2.0 and possibly resinstall but thought I'd ask to see if this is a known bug.
Oh BTW running:
Mac OS X 10.7.5
Thanks!
Andy
Screen Shot 2013-10-06 at 5.02.37 PM.png (821.7 KiB) Viewed 498 times
AndrewRomer
Re: Very weird color issue
by AndrewRomer » Sun Oct 06, 2013 10:45 pm
Worked with it a bit - fixed it. Pretty sure it had to so with the file format .psd Each face was ~1.4gb and I routinely use psd/b to be safe but somehow PTP 2.0 doesn't like psd.
