Hotspot selecting invariably moves hotspot
stillstonevisions
by stillstonevisions » Sun Oct 06, 2013 7:24 pm
Whenever I select a hotspot in order to change parameters and settings, the hotspot invariably is unintentionally moved significantly. There needs to be a way to select the hotspot without moving it.
Re: Hotspot selecting invariably moves hotspot
by mediavets » Sun Oct 06, 2013 8:21 pm
stillstonevisions wrote:Whenever I select a hotspot in order to change parameters and settings, the hotspot invariably is unintentionally moved significantly. There needs to be a way to select the hotspot without moving it.
Not if you use the Select button before selecting the hotspot.
stillstonevisions
by stillstonevisions » Sun Oct 06, 2013 8:31 pm
Ok, good. Glad that has been handled. Thanks.
