Panotour 2.0 not running on Suse 11.4
hannes
by hannes » Sun Oct 06, 2013 3:46 pm
hannes@Pundit2:~/SOFTWARE/PHOTO/PANO/TOUR/Panotour_2> ./Panotour
./Panotour: error while loading shared libraries: libKGFL_linux64.so: cannot open shared object file: No such file or directory
but libKGFL_linux64.so is in the folder and executable ...
second try:
hannes@Pundit2:~/SOFTWARE/PHOTO/PANO/TOUR/Panotour_2> ./Panotour.sh
hannes@Pundit2:~/SOFTWARE/PHOTO/PANO/TOUR/Panotour_2> QLayout: Attempting to add QLayout "" to KuiFrameCollapsible "frameCollapseGeolocalisation", which already has a layout
QLayout: Attempting to add QLayout "" to KuiFrameCollapsible "frameDescription", which already has a layout
QLayout: Attempting to add QLayout "" to KuiFrameCollapsible "frameColor", which already has a layout
QLayout: Attempting to add QLayout "" to KuiFrameCollapsible "frameOrder", which already has a layout
QLayout: Attempting to add QLayout "" to KuiFrameCollapsible "frameBackgroundSound", which already has a layout
QLayout: Attempting to add QLayout "" to KuiFrameCollapsible "frameAuthor", which already has a layout
QLayout: Attempting to add QLayout "" to KuiFrameCollapsible "frameCollapsibleFloorPlan", which already has a layout
QLayout: Attempting to add QLayout "" to KuiFrameCollapsible "frameRotation", which already has a layout
QLayout: Attempting to add QLayout "" to KuiFrameCollapsible "frameStartParams", which already has a layout
QLayout: Attempting to add QLayout "" to KuiFrameCollapsible "frameDisplay", which already has a layout
QLayout: Attempting to add QLayout "" to KuiFrameCollapsible "frameProjection", which already has a layout
QLayout: Attempting to add QLayout "" to KuiFrameCollapsible "frameView", which already has a layout
QLayout: Attempting to add QLayout "" to KuiFrameCollapsible "frameNadir", which already has a layout
QLayout: Attempting to add QLayout "" to KuiFrameCollapsible "frameAdvanced", which already has a layout
QLayout: Attempting to add QLayout "" to QGroupBox "groupBoxSpotParameters", which already has a layout
terminate called after throwing an instance of 'KException'
QThread::start: Thread creation error: Die Ressource ist zur Zeit nicht verfügbar
Likes: 84 posts
Liked in: 188 posts
Re: Panotour 2.0 not running on Suse 11.4
by benji33 » Mon Oct 07, 2013 10:45 am
Thanks for report we'll have to check the Linux installer.
Likes: 13 posts
Liked in: 124 posts
by bdd » Mon Oct 07, 2013 11:09 am
We opened an issue 2597 on this subject.
Likes: 13 posts
Liked in: 124 posts
by bdd » Fri Oct 18, 2013 11:43 am
We did some changes in the 2.0 Beta 2 version that may fix this issue.
But we are not sure of that as we were not able to reproduce it.
That's why it does not appear in the changelogs of this new version.
Can you tell us if this exception still occurs with the 2.0 Beta 2 version ?
hannes
by hannes » Mon Oct 21, 2013 1:59 pm
it is the same with beta 2 - still not running - same output
Likes: 84 posts
Liked in: 188 posts
by benji33 » Mon Oct 21, 2013 2:36 pm
Thanks for your response. I've added your report on the opened bug.
ygilquin
by ygilquin » Tue Oct 22, 2013 4:01 pm
We tried Panotour Pro 2.0 Beta2 under OpenSuse 12.3 (last version) and it starts without any problem.
You should also never launch ./Panotour command directly, but invoke ./Panotour.sh wrapper script which sets the environment.
Anyway, this is definitely not a problem with the package but a runtime compatibility problem. You should ensure you're running binaries with the right architecture (32/64 bits) depending on your system.
hannes
by hannes » Tue Oct 22, 2013 4:16 pm
no big problem - because I have a PC with ubuntu 12.04 were its running without problems
Likes: 84 posts
Liked in: 188 posts
by benji33 » Wed Oct 23, 2013 8:32 am
Yes panotour is designed and tested for Ubuntu but may work on others Linux versions.
ygilquin
by ygilquin » Fri Jan 03, 2014 9:47 am
For information Panotour Pro 2.0 RC1 runs perfectly in OpenSuse 12.3 on our side.
