PTP2 crashes if you click a hotspot during load
scoopz
by scoopz » Sun Oct 06, 2013 12:09 pm
[Version Beta 1]
When I first open a large project it can take while to generate all the pano thumbs again (can these thumbs be saved as part of the project to prevent regeneration each time?). Sometimes I just want to make a small change to a hotspot that already exists, if I click a hotspot before all the pano thumbs have loaded PTP2b1 crashes every time.
I have tested on multiple tours and it happens each time. I assume it's because clicking on a hotspot triggers the actions tab for that hotspot to try and load the list of available panos to link to and their previews, which are still being generated?
I thought that because you aren't locked out of the app whilst the previews load it meant you could do other things whilst the previews regenerated in the background but perhaps not?
Test System Spec: 15" Retina MacBook Pro, 2.7GHz i7, 16GB RAM, 768GB SSD, OS X Yosemite
Re: PTP2 crashes if you click a hotspot during load
by mediavets » Sun Oct 06, 2013 12:30 pm
Which version of PTP 2.x are you using?
scoopz
by scoopz » Sun Oct 06, 2013 12:32 pm
Sorry I forgot to include that in the post, I'm using beta 1.
I've edited OP with this info
scoopz
by scoopz » Sun Oct 06, 2013 12:35 pm
Here's the OS X crash report it generates
Process: KCrashReporter [4658]
Path: /Applications/Panotour Pro 2.0.app/Contents/MacOS/KCrashReporter
Identifier: KCrashReporter
Version: ???
Code Type: X86-64 (Native)
Parent Process: ??? [1]
User ID: 501
Date/Time: 2013-10-06 12:34:36.706 +0100
OS Version: Mac OS X 10.8.5 (12F37)
Report Version: 10
Crashed Thread: 0
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: /usr/local/Trolltech/Qt-4.8.5/lib/QtGui.framework/Versions/4/QtGui
Referenced from: /Applications/Panotour Pro 2.0.app/Contents/MacOS/./KCrashReporter
Reason: image not found
Binary Images:
0x100000000 - 0x10000dfff +KCrashReporter (???) <2DFA9D07-471B-354E-94E3-F58ECF647668> /Applications/Panotour Pro 2.0.app/Contents/MacOS/KCrashReporter
0x7fff61134000 - 0x7fff6116893f dyld (210.2.3) <A40597AA-5529-3337-8C09-D8A014EB1578> /usr/lib/dyld
0x7fff8df77000 - 0x7fff8e2d6fff com.apple.Foundation (6.8 - 945.18) <1D7E58E6-FA3A-3CE8-AC85-B9D06B8C0AA0> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
Reason: Image not found.
