Action Parameter not showing panorama
scoopz
by scoopz » Sun Oct 06, 2013 11:18 am
When adding hotspots about 90% of the time the Action Parameters tab doesn't show the target panorama and the preview window in tiny. Dragging the corner grab handle makes this bigger but then it shows no image and you have to deselect and reselect the target panorama from the dropdown list to make it load.
Present in Beta 1 and has been the case in alpha versions too on OS X 10.8.5 on a retina macbook pro.
Screen Shot 2013-10-06 at 11.05.57-1.jpg (45.27 KiB) Viewed 797 times
Screen Shot 2013-10-06 at 11.14.39-1.jpg (101.7 KiB) Viewed 797 times
scoopz
Re: Action Parameter not showing panorama
by scoopz » Sun Oct 06, 2013 11:58 am
OK so it looks like this could be attributed to the retina display on my macbook Pro.
Using the default "Best for retina display" setting
and then click on a hotspot I get
If I change the system resolution to "scaled" and force a higher resolution
If I change the system resolution to "scaled" and force the highest resolution
But I don't have this issue when using PTP2 on a non-retina macbook with a smaller 13" screen.
I've also tried selected "open in low resolution mode" on the app properties
but that made no difference to this issue.
I'd suggest anybody running PTP2 on a retina MabookPro switches from the default "best for retina" system resolution to the highest possible resolution for now if they wish to avoid not seeing target pano without resizing the preview window each time.
