Panorama menu display
vesnice8
by vesnice8 » Fri Oct 04, 2013 4:11 pm
Hello Kolor hello Community
Unfortunately I got a problem I can't solve out.
At the top I have a colored area. In this area is the panorama menu on the left.
To display the tour with PTP click play (view last built tour). Great, everything works.
Now opening the Tourfile on Desktop. Klick .html show tour. Tour is displayed but no panorama menu.
Tried firefox and explorer. Then tried on Notebook. Still the same.
Why, I can't find any solution....
Thanxs for help and greets
Ps: Title and simple button is displayed only panorama menu not
Win7 x64
Update: The simple button is linked with social share, It shows the simple button (png.), but not
the button itself, (FB,Mail etc.) by opening on desktop html. file.
Update:
Online no prob. works fine
Re: Panorama menu display
by mediavets » Fri Oct 04, 2013 5:40 pm
vesnice8 wrote:Hello Kolor hello Community
Win7 x64
the buttons itself, (FB,Mail etc.) by opening on desktop html. file.
Many more features in PTP 2.x are implemented in javascript - to work correctly the tour must be delivered from a web srever.
PTP 2.0 has a small built-in web serevr which is used when you use the View last built tour button for local viewing, in which case all javascript features will work.
And that's why these features don't work when you simply open the HTML file locally with the browser.
vesnice8
by vesnice8 » Sat Oct 05, 2013 1:06 am
Hey there
Thank you very much. Understand
Kind regards
