KRPano WebVR oversampling factor
BrianLR
Likes: 3 posts
by BrianLR » Thu Sep 06, 2018 12:51 am
What value does PTP use for oversampling in the KRPano WebVR plugin, the default is 1.0 .Is there a way to change it in the xml files and where?
https://krpano.com/plugins/webvr/#oversampling
The oversampling factor for the rendering.
Higher values can increase the quality, but require more GPU processing power.
Lower values will lower the quality and require fewer GPU processing power.
Re: KRPano WebVR oversampling factor
by benji33 » Fri Sep 14, 2018 9:32 am
Into the YOURTOUR_core_vr.xml file yes you can. Have a look on the webvr plugin into this file to change/add this value.
BrianLR likes this post.
