Panotour Duplicating Template Files on Build
mikepostons
Likes: 4 posts
Liked in: 5 posts
by mikepostons » Thu Aug 30, 2018 1:17 pm
Hi guys,
have noticed an issue with the latest version of Panotour Pro (V2.5.14). Whenever I build the project, Panotour seems to be creating duplicates for each of the files from the template.
You can see this in the attached screenshots. Although it's obviously possible to clean this up using the 'Manage Build Files' system, it's not ideal.
Any thoughts on what might be causing this?
Many thanks
Mike
Duplicated files in build.
Re: Panotour Duplicating Template Files on Build
by benji33 » Fri Sep 07, 2018 2:23 pm
It's a known issue for Templates files with resources.
You can delete all the unneeded copied resources at the end.
This was to avoid replacement of internal resources but in your case it's also applied to external resources.
