A tour featuring Language selection and Audio information
Julien
Likes: 15 posts
by Julien » Tue Aug 28, 2018 4:06 am
Hi, bonjour, hallo,
I was looking to work on a project with 2 languages, plus 2 audio files or 2 video clips with their soundtrack. I definitly like my audio files or video clips to be affected by the change of the language selection.
This doesn't seems to be possible. Can it be confirmed please?
Other tips are very welcome :rolleyes:
Thank you, merci, danke.
PS:
I found one post 'Using a virtual tour with audios in 4 languages' and waiting for its author to reply to my private message... viewtopic.php?f=91&t=34226&p=191718&hilit=language+audio+file#p191718
Panotour Pro v2.5.7
Macbook Pro OSX 10.10.5 Yosemite
Re: A tour featuring Language selection and Audio informatio
by benji33 » Tue Aug 28, 2018 9:10 am
Not possible from the GUI.
You have to edit the generated code to use filenames with suffix for instance.
So when you call audio1.mp3 for instance, you have to call the audio1_en.mp3, audio1._de.mp3 or audio1_es.mp3 for instance. The current language string "en", "de" or "es" for instance is stored into the tourLanguage variable.
Is it a play audio action or a background scene sound (more complicated to edit) ?
For video files it depends if it's a Display video action, video spot, video scene etc...
Julien
Likes: 15 posts
by Julien » Tue Aug 28, 2018 2:00 pm
Thanks Benji,
I'm too sure yet witch option I will choice, firstly I'm looking for technical information. And I think I get your points. Thanks for the call. I will get back if needed.
Julien
Panotour Pro v2.5.7
