Incorrect title in Gallery
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Mon Aug 27, 2018 5:53 am
Hi
When I create a new image gallery (or duplicate an existing one) the titles are incorrect. It appears to display the titles from the first gallery created.
Any help appreciated.
Steve
Titles set in Panotour
Resultant incorrect titles
signmaster
Likes: 52 posts
Liked in: 36 posts
Re: Incorrect title in Gallery
by signmaster » Mon Aug 27, 2018 6:48 am
I deleted all the galleries and started again and it is now working? Had a similar problem with the Sidebar plugin, deleted and started again and it's OK now. Not sure what is going on.
by benji33 » Tue Aug 28, 2018 8:49 am
Seems to be related to internal ID issues into the project.
Start again is always good in this case but time consuming I know.
signmaster likes this post.
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Thu Sep 06, 2018 4:52 am
The same problem again, massive job to start again and I have a lot of galleries to add. This is now a real problem for me. I have spent a lot of time trying workarounds. Any help appreciated.
Steve
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Thu Sep 13, 2018 8:07 am
Resorted to starting from scratch again, this time completely from scratch and not duplicating any galleries, About 6 hours work but all is OK. Not sure what happened but perhaps it is not the best thing to duplicate galleries??
Steve
by benji33 » Fri Sep 14, 2018 8:17 am
It's an internal issue of the program with elements lists used into the Gallery plugin.
The ID can be corrupted.
The best way is to define correctly all gallery at start even with unneeded entries then remove the remaining unneeded entries once project is finalized.
Users browsing this forum: No registered users and 10 guests
