FloorPlan change order   [SOLVED] - View the solution
Ramona86
by Ramona86 » Fri Aug 17, 2018 3:42 pm
Hi, is it possible in retrospect to change the order of the floor plan selection? See image.
I tried it in the ... message.xml but unfortunately he doesn't do it.
Does one have an idea to change that without having to rebuild the whole tour?
I would be very happy about your help. Many Thanks.
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
Re: FloorPlan change order  [SOLVED]
by 360-compunics-com-ni » Sat Aug 18, 2018 12:16 pm
You can reorder the group sequence by moving the correponding definitions in the <your-project-name>_skin.xml-file as shown below.
But this will only change the sequence for the floorplan menu, it does not change the startscene or the sequence of the panos when accessed via "next/previous"-buttons, for example, so depending on your tour navigation this might confuse tour visitors. Re-ordering the scenes is also possible but i would recommend to use the GUI and rebuild the tour if possible.
Ramona86 likes this post.
Ramona86
by Ramona86 » Sat Aug 18, 2018 3:04 pm
Thanks for your feedback. I have test it and it works perfectly:-) Many thanks for your help and your great solution.
I wish you a nice saturday.
