show 180 degrees
ken1127
show 180 degrees
by ken1127 » Sun Aug 12, 2018 12:47 pm
Hello, I want to ask
a 360 degree view
I only hope to show 180 degrees.
In panoture software
How should I set it?
Thank you
Re: show 180 degrees
by benji33 » Fri Aug 17, 2018 12:29 pm
180° horizontally ?
There is a trick. Change the horizontal value to 359°
Then use the crop tool into the hotspot editor and define the 180° portion.
Then Change the horizontal value of the scene to 360°
ken1127
by ken1127 » Tue Aug 28, 2018 7:18 am
Where is the setting horizontal ?
On the “ptp” software?
Please give more guidance
by benji33 » Tue Aug 28, 2018 9:14 am
Select the scene.
Into the right part of the software You can setup the horizontal, vertical and vertical offset values of the view/projection.
http://www.kolor.com/wiki-en/action/vie ... Projection
Do the 359° trick here.
Once done the crop tool is into the Hotspot editor into the bottom left of the screen.
http://www.kolor.com/wiki-en/action/vie ... ditor#Crop
