Editing the help screen
bern8829
Likes: 3 posts
by bern8829 » Tue Jul 31, 2018 8:42 am
I have a symbol in my tour that switches between day and night. I want to include the symbol in the help section so users know what to do with the symbol
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
Re: Editing the help screen
by 360-compunics-com-ni » Tue Jul 31, 2018 9:50 am
Assuming that you use the ClassicControlbar, there are two files used for the helpscreen, for the foreground and the background, they are located in the "<your-project-name>data/graphics/classiccontrolbar"-folder (or .../classiccontrolbar1 if you have 2 instances of the controlbar). The names are "help_screen_fg.png" and "help_screen_bg.png", the problem when modifying these files is that they get overwritten with PTP's original files each time you re-generate the tour.
So it would be wise to save a copy of the modified versions to be able to do the replacement again if that becomes necessary, or to have a custom plugin to automatically replace the files each time the tour gets generated.
And yes, i do offer such programming services :)
bern8829 likes this post.
bern8829
Likes: 3 posts
by bern8829 » Tue Jul 31, 2018 8:32 pm
LOL. Thank you very much
