Help Screen Display   [SOLVED] - View the solution
bern8829
Likes: 3 posts
Help Screen Display
by bern8829 » Mon Jul 30, 2018 9:58 am
How do I ensure that the help screen is the first thing a user sees before navigating the tour ?
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
Re: Help Screen Display
by 360-compunics-com-ni » Mon Jul 30, 2018 2:26 pm
You can use the "Call actions on tour events"-plugin to display the helpscreen, but the name of the action to be called depends on the controlbar you are using in your project.
For example, when using the "Sans Controlbar" the action to call would be: "SansControlBardisplayHelp();"
So search in the "<your-project-name>_skin.xml"-file for an action that is named something like "<XY>displayHelp" and use that with the advanced "Call custom code"-function on the Tourstart-event.
bern8829 likes this post.
bern8829
Likes: 3 posts
by bern8829 » Mon Jul 30, 2018 5:12 pm
360-compunics-com-ni wrote:You can use the "Call actions on tour events"-plugin to display the helpscreen, but the name of the action to be called depends on the controlbar you are using in your project.
My action name is controlBar_classic1displayHelp. I dont have the call custom code option in the advanced section of the call actions on tour events.
Likes: 15 posts
Liked in: 163 posts
Re: Help Screen Display  [SOLVED]
by 360-compunics-com-ni » Mon Jul 30, 2018 5:39 pm
That action has become standard with the current version 2.5.13 of PTP. If you use an old version you have to install it first, please have a look at the install instructions which are slightly different for plugins and for actions:
http://www.kolor.com/wiki-en/action/view/Panotour_-_Advanced_-_Extra_Plugins
bern8829
Likes: 3 posts
by bern8829 » Tue Jul 31, 2018 8:34 am
Awesome It worked perfectly. Thank you
