Panotour Viewer moves uncontrollably on Samsung S6   [SOLVED] - View the solution
justinmih
Liked in: 3 posts
by justinmih » Tue Jul 24, 2018 12:05 am
Hi
I have been using panotour viewer successfully for a long time but recently it has stopped functioning correctly on my Samsung S6. When i go in to the VR mode the splits screens start moving uncontrollably and nothing i do seems to fix it.
Has anyone else had this same issue and does anyone know what to do to fix it? I think the issue is on the Samsung phone rather than panotour viewer but just wondered if there was a way to fix it. I have an event on Saturday that i plan to use panotour viewer as i wont have access to WiFi and i need to find a solution quickly. I have 2 Samsung s6 phones and both are doing the same thing.
Thank you for any help you can give in fixing this.
Kind Regards
Justin
justinmih
Liked in: 3 posts
Re: Panotour Viewer moves uncontrollably on Samsung S6
by justinmih » Thu Jul 26, 2018 12:45 am
If anyone else is experiencing this issue you need to recreate and upload the tour and then it solves the issue.
Kind Regards
Justin
