Mute video on Ipad does not work
luca
by luca » Tue Jul 10, 2018 10:51 am
Hi, I have a problem with video hotspot on Ipad. Also if i flag "mute video" in PTP, sound is playing. It works ok on other devices. Can anyone help?
Luca
Likes: 14 posts
Re: Mute video on Ipad not work
by bdd » Tue Jul 10, 2018 2:19 pm
I reproduce the issue on on our side.
We will fix it for next fix release.
Meanwhile, if you are confident with XML and code edition you can do the following after the tour is built (beware that another build done after the edition will erase your changes) :
  1. Edit the xxx.xml file (where xxx is the filename of your tour.)
  2. Find all the actions named "onclickspotvideoXYXYX" where XYXY is the ID of the video spot
  3. In these actions, find the line :
                      set(hotspot[spotvideoXYXY].muted, false);
  4. Replace it by :
                      set(hotspot[spotvideoXYXY].muted, true);
  5. Edit the xxx_skin.xml file
  6. Find the action named onvideoreadyRectVideoDefaultVideoSpotStyle
  7. In this action, find the line :
              set(muted, false);
  8. Replace it by :
              set(muted, true);
