multiple floor plan scroll bar
360andmore
by 360andmore » Mon Jul 09, 2018 2:03 pm
I've added floor plans to 30 groups of panorama and chose a multiple floor plan.
Within the tour, the floor plan window show my first floor plan. But the dropdown menu to select the other floor plans don't show all the further floor plan, because I can't scroll down.
There is noch scroll bar visible. No chance to enter the last 15 floor plans.
How does it work to make the missing floor plans visible or how can I get a scroll bar in there?
Likes: 14 posts
Re: multiple floor plan scroll bar
by bdd » Tue Jul 10, 2018 10:50 am
You can't do it directly thru Panotour Pro interface.
But you can change the floorplan CSS files once the tour is built.
Here's how :
  1. Step into the subdirectory "xxxdata\graphics\KolorFloorPlan" where xxx is the filename of your tour.
  2. Edit the CSS file called kolorFloorPlan.css
  3. Add the following code at the beginning of the file :
    div.floorplanDropDownOptionsDiv {
       max-height:200px;
       overflow:scroll;
360andmore likes this post.
360andmore
by 360andmore » Tue Jul 10, 2018 11:48 am
You made my day!!
=D
