WebSiteBox slide effect
foxlarsson
by foxlarsson » Thu Jun 28, 2018 9:08 am
Hi for all,
Is there any way to display the WebSiteBox through a slide effect (motion) to the right or left (top or bottom). I do not know the syntax of krPano well, that's why I'm asking this question. Maybe someone has a ready-made solution?
Likes: 14 posts
Re: WebSiteBox slide effect
by bdd » Mon Jul 02, 2018 10:02 am
This feature is not yet implemented on Website Box plugin.
This plugin is not handled by krpano player. So knowing krpano syntax will not help.
It's a plugin written in JavaScript displayed over the player.
davyk
by davyk » Sat Sep 01, 2018 12:30 am
So how can we do ?
is it possible to implement the same effects than the Description plugin ?
regards,
Victor
davyk
by davyk » Sat Sep 01, 2018 1:58 am
Ok I found a solution :
1. Write whatever you want in the hotspot description let's say : "MY DESCRIPTION TO TRANSFORM"
1b. Setup your "Description" plugin to show "current spot" in the "Description to display" settings.
1c. You can select the animation you want il the Animation settings
2. Generate the tour
3. Open your language xml file for example if you're french and you named your project index.html it will be index_messages_fr.xml
4. In the file you find :
<![CDATA[MY DESCRIPTION TO TRANSFORM]]>
5. You replace it by :
<![CDATA[<iframe  sandbox="allow-same-origin allow-scripts allow-popups allow-forms"   style="position:absolute; border:0; padding:0;top:0;left:0;margin:0; width:100%; height:100%" src="YOUR LINK></iframe>]]>
6. Save your file.
REMEMBER : if you regenerate your project in panotour, your xml file will be overwritten so, you'll have to redo everything.
Regards,
Victor
