How to make a floorplan proportionally scale?
Strider
by Strider » Thu Jun 28, 2018 12:41 am
I can't make a floorplan bitmap scale proportionally. I don't want to hard code the bitmap's size in pixels because it doesn't scale proportionally to the display medium (e.g. cell phone). I've tried setting in an Area Width in Percentage, then 0 pixels for the height, but it displays 0 pixels tall (unviewable). This same trick seems to work elsewhere such as button bitmaps.
How do I make the floorplan scale proportionally if I define a width % *or* a height %? (e.g. if height is chosen, width would dynamically scale proportionately, and vice-versa).
Thanks!
Re: How to make a floorplan proportionally scale?
by benji33 » Mon Jul 30, 2018 9:29 am
It's a know issue, because the defined size is for the Floor Plan container and not the Floor Plan image itself.
