Click on graphic to display floorplan
Strider
by Strider » Fri Jun 22, 2018 7:29 pm
I'm learning how to use Call Actions On User Events and right now I have a half-solution up and going.
I want to have a small floorplan image on the top left corner. When the user clicks on the image, the full sized floorplan should pop out. Right now it mostly works except the User Event is the entire window instead of just the image. Is there some way to make the floorplan open only if the small image is clicked (not outside of that image)?
Thanks!
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
Re: Click on graphic to display floorplan
by 360-compunics-com-ni » Sat Jun 23, 2018 11:42 am
There is no need to use the "Call Actions On User Events" plugin for that, you can use an ordinary button with your image and assign the "open/close floorplan" action to it.
Strider
by Strider » Sat Jun 23, 2018 4:54 pm
Ahh Brilliant! Thank you so much.
Users browsing this forum: No registered users and 8 guests
