Start tour with hideable controls hidden o only mobile dev.
Martas133
by Martas133 » Thu Jun 14, 2018 8:45 am
Hi, is there any way to start tour with hidden options only on mobile devices (i mean smartphones and tablets) without buying DeviceCheck plugins by Michael Brüning ? I now that there is an option in Properties, but it will start with hidden controls always, even on PC. I now that tour recognize mobile devices because it always displays gyroscop and VR icon only on mobile devices, so is it somehow possible ? Thanks everyone !
Likes: 14 posts
Re: Start tour with hideable controls hidden o only mobile d
by bdd » Thu Jun 14, 2018 9:39 am
Yes it's possible, with following "advanced method" :
  1. Be sure that the option "Start tour with hiddeable controls hidden" is UN-checked
  2. Add the plugin "Call actions on tour events" in your project
  3. Check the "Starting the tour" event
  4. Select the advanced action : "call krpano code"
  5. Enter the following code :
    if (device.mobile, hideTourControls(), showTourControls());
  6. Build the tour
Martas133 likes this post.
Martas133
by Martas133 » Thu Jun 14, 2018 11:14 am
Thank you very much for you answer ! It works ! I have one more question, is there some code for hiding either floorplan ? In Floor plan -> Behaviors I have option Start opened checked.
I want floorplan to start opened on PC and on mobile devices closed.
I tried
if (device.mobile, floorPlanCloseTourFloorPlan(),floorPlanOpenTourFloorPlan());
But it does'nt work.
Thanks !
Likes: 14 posts
by bdd » Thu Jun 14, 2018 12:17 pm
As you want to control the opening by yourself, un-check the "Start opened" property.
And use this code instead of yours :
if (device.mobile, hideFloorplan(),showFloorplan());
