Panotour Pro and Touchscreens
Pvmi
by Pvmi » Tue May 15, 2018 4:18 pm
Hi All,
New to the forum so forgive me if this question has been asked elsewhere (they usually have!)
I am in the process of creating a Panotour build which currently works fine on html and Panotour viewer as far as functionality is concerned. I have recently been informed however that the client has decided to run the experience on a touchscreen as well. Having tested on a Samsung galaxy tab it appears to be running fine, however, I have had complications in the past when such files are subsequently ported onto large screens.
Has anyone any experience in this regard? My gut instinct says there shouldn't be an issue, however, I don't have a large touch screen to test currently.
Many thanks in advance!
Re: Panotour Pro and Touchscreens
by benji33 » Mon Jul 30, 2018 9:10 am
Normally Panotour is designed to run on touch screens devices.
Some issues exists with the FloorPlan plugin for instance on some devices.
