Title-extended free plugin not working
rosco
Liked in: 5 posts
by rosco » Mon May 14, 2018 11:42 am
As in the subject, I tried to add the free plugin named 'Title - extended', but it doesn't work. I don't get any text, neither using it in a specific pano/group nor using it in all the panos/groups.
So how can I get the plugin working? Please help.
Thanks,
Alessandro
Likes: 14 posts
Re: Title-extended free plugin not working
by bdd » Wed May 16, 2018 8:37 am
What are your settings for this plugin ?
Can you share either a screenshot of them, or an URL of a tour that contains a title-extended plugin with this error ?
rosco
Liked in: 5 posts
by rosco » Wed May 16, 2018 4:06 pm
Here are the settings:
No text appears in the VT, no matter what settings I try to modify.
rosco
Liked in: 5 posts
by rosco » Thu May 24, 2018 12:43 pm
Still any solution?
Likes: 14 posts
by bdd » Tue May 29, 2018 9:39 am
The plugin is working correctly with these settings.
Are the "tour controls" displayed ?
rosco
Liked in: 5 posts
by rosco » Tue May 29, 2018 7:16 pm
What do you mean with 'tour controls'?
All other plugins work properly. As a matter of fact, the 'title' plugin works fine.
So what's wrong with 'title-extended' plugin?
Likes: 14 posts
by bdd » Wed May 30, 2018 8:27 am
Can you send me either an URL of a tour where the extended title does not work, or a project file ( *.kpt ) ?
As I said I did a test with the same parameters as yours, and it works fine.
What may happen, in your case, as the property "respond to hide/show tour controls request" is checked, is that the title is not displayed because you told the project to hide the controls .
Julien
Likes: 15 posts
by Julien » Fri Aug 24, 2018 1:25 pm
Hi Gérald, it seems I'm facing the same issue.
My 'Title plugin' and 'Title Extended plugin' are set with the same Behavior 'Respond to show/hide controls requests' is unchecked.
I'm launching the project with my "tour controls" none displayed.
- The Tile plugin pop up normally.
- The Title Extended plugin not pop up
I've sent you my .kpt for a look at this.
Julien
Panotour Pro v2.5.7
Macbook Pro OSX 10.10.5 Yosemite
Likes: 14 posts
by bdd » Tue Aug 28, 2018 9:25 am
Julien wrote:Hi Gérald, it seems I'm facing the same issue.
Julien
Hi Julien,
You are right there is a bug if the option "Respond to show/hide controls requests" is unchecked for the "Extended title".
Download the following zip file
titletextfield.zip
(1.64 KiB) Downloaded 81 times
It contains the file "titletextfield.tmpl" .
1/ In Panotour Pro, click on the menu : "Edit/Open Templates System Directory"
2/ Go down into the sub folder : "plugins"
3/ Go down once more in the subfolder : "extendedtile"
4/ In this folder there is already a file named "titletextfield.tmpl", rename it "titletextfield_original.tmpl"
5/ Copy there the above file
6/ Restart PTP and rebuild the tour
Julien
Likes: 15 posts
by Julien » Tue Aug 28, 2018 2:22 pm
Hi Gérard,
I confirm the above zip fixed my problem!
Good to feel giving a hand to your team :)
Topic not 'Solved' as I'm not its author.
Julien
Panotour Pro v2.5.7
rosco
Liked in: 5 posts
by rosco » Tue Aug 28, 2018 2:48 pm
Glad to know that this issue seems to be fixed.
As I'm abroad now I can not test the fix.
As soon as I come back I'll try it and if it works for me too I'll mark the topic as 'solved'.
