Project duplication
MerrynW
Project duplication
by MerrynW » Sun May 06, 2018 10:01 am
Is it possible to duplicate a project to enable different versions featuring e.g. alternative interfaces and functionality?
I tried saving a completed project under a different name but it seems to messed up the filepaths to the original project.
Thanks.
Merryn
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
Re: Project duplication
by 360-compunics-com-ni » Sun May 06, 2018 5:42 pm
You can do that by selecting a different output folder on the "create"-tab, and using the "File - save (extended) as"-option.
Together with the project file an additional folder is saved containing the resource files that are used by that tour.
MerrynW
by MerrynW » Mon May 07, 2018 7:28 am
Thanks! :)
