Change color of a Point Style Text   [SOLVED] - View the solution
jimandsue60
Likes: 4 posts
Liked in: 3 posts
by jimandsue60 » Sat May 05, 2018 12:09 am
I have set up a point with a marker icon but can not change the color of the text. I am sure it is something simple but the client wants a different color for the text. Here are a couple of screen shots. and the pano.
Re: Change color of a Point Style Text
by Destiny » Sat May 05, 2018 1:37 am
In Tool Tip box.. Try this.. <font color="red">This is a red tool tip</font> etc...
http://members.westnet.com.au/dps/Colou ... olour.html
jimandsue60
Likes: 4 posts
Liked in: 3 posts
by jimandsue60 » Sat May 05, 2018 12:12 pm
Your link did not work, I tried pasting this into the tool tip box and it did not work <font color="red">
by Destiny » Sat May 05, 2018 11:11 pm
Did you try via the Green Preview Last Pano button.. Or on line.. Its HTML code so it needs a web server to work.. You can also use the krpano Testing Sever...
jimandsue60 likes this post.
jimandsue60
Likes: 4 posts
Liked in: 3 posts
Re: Change color of a Point Style Text  [SOLVED]
by jimandsue60 » Sat May 05, 2018 11:14 pm
I am not the best on HTML but put the color code in front of the text I wanted to change the color of and it worked. Thank you for the help.
