It is possible mix image and text?
pitigarcia
by pitigarcia » Sun Apr 22, 2018 9:00 am
It is possible mix image and text? like
a text box accompanied by an image in a popup window?
thanks in advance
Re: It is possible mix image and text?
by Destiny » Sun Apr 22, 2018 10:57 am
You can.. But if you use a Description, you an use html image tag to add the images via the xml code. Build your Tour and then check out the *_messages_en.xml file where you have your words. Then add this below into it...
Tag code should be something like this.. <img src="http://www.where/name.jpg" width="800" height="600" />
Add the images into your file structure and upload..
.. Or you can use Website Box with an image and text...
pbetancourt
Likes: 25 posts
Liked in: 7 posts
by pbetancourt » Wed Apr 25, 2018 3:39 am
Have you tried Gallery plugin?
