map distance plugin   [SOLVED] - View the solution
erandan2000
map distance plugin
by erandan2000 » Tue Apr 03, 2018 4:16 pm
hi ,
my costumers are asking me if i can add some kind of plugin that will show the distance between panoramas, for an example . the main panorama is 6 mile distance from the other hot spot..is there any solution for this?
thank you
eran
Re: map distance plugin
by benji33 » Thu Apr 19, 2018 4:25 pm
Not yet but it's a real good idea ... if your panoramas are geolocated of course ;)
erandan2000
by erandan2000 » Sun May 20, 2018 10:10 am
Is that a plugin that will be available soon?
by benji33 » Mon Jul 30, 2018 9:05 am
A new tooltip entries allows you to do that (only for tooltips since Panotour Pro 2.5.12) if your panoramas are geolocated :
%DISTANCEINMETERS% - Display the number of meters between the 2 scenes
%DISTANCEINKILOMETERS% - Display the number of kilometers between the 2 scenes
%DISTANCEINMILES% - Display the number of miles between the 2 scenes
%DISTANCEINYARDS% - Display the number of yards between the 2 scenes
%DISTANCEINFEET% - Display the number of feet between the 2 scenes
erandan2000
by erandan2000 » Mon Aug 06, 2018 9:27 am
please explain. how do i get to this tooltip after i finish the virtualtour? how can i do this ? do you have any video to show? please advise
Re: map distance plugin  [SOLVED]
by benji33 » Mon Aug 06, 2018 3:37 pm
There is no video, but :
1. go to the Style tab
2. select the Point spot style used for hotspots links between scenes (with "Go to panorama" action)
3. Into the tooltip field, fill with %DISTANCEINMETERS%
4. Test it
If scenes are geolocated, the tooltip should be displayed on hover with the distance in meters between the 2 scenes.
erandan2000
by erandan2000 » Mon Aug 06, 2018 5:11 pm
can you show any example for this please
erandan2000
by erandan2000 » Mon Aug 06, 2018 5:22 pm
here is a tour that i create , i put this on one of the baloon hotspot and i cant see any changes please advise
http://topeye.club/spherikal/carmi/
erandan2000
by erandan2000 » Mon Aug 06, 2018 5:27 pm
o.k it work now i got it thanks ))
