Switch GYROSCOPE custom code
dadoplus
Likes: 30 posts
Liked in: 9 posts
by dadoplus » Mon Mar 19, 2018 4:21 am
Hi guys,
I need to switch gyroscope state with the same button (one of top menu plugin by alexpopov). Since the default action in panotour still needs 2 different "slots" and top menu does not support it, I was thinking of using call custom code action or call a javascript function but I can't seem to understand exactly the code to do the trick.
Any ideas? I thought this was the action but doesn't seem like it.
<action name="changeGyroscopeState">
  if(plugin[gyroscope],
    if (plugin[gyroscope].isavailable,
        if(%1,
          set(plugin[gyroscope].activated,true);
          set(plugin[gyroscope].activated,false);
        if (%1 != plugin[gyroscope].enabled,
          if(plugin[gyroscope].activated,
            switch(plugin[gyroscope].enabled);
            set(plugin[gyroscope].enabled, false);
          if (plugin[gyroscope].enabled, events.dispatch(ongyroscopeon);, events.dispatch(ongyroscopeoff););
</action>
Thanks!
Re: Switch GYROSCOPE custom code
by benji33 » Thu Mar 22, 2018 11:01 am
You would like a toggle rather than the Enable & Disable actions ?
It means: set activated to true is false prior and vice versa.
If yes, try this code.
<action name="toggleGyroscope">
   if(plugin[gyroscope],if (plugin[gyroscope].isavailable,
      <!-- toggle gyroscope if activated in the tour -->
      <!-- fire Panotour event for the current gyroscope state -->
</action>
Yes, you can call a krpano custom code or uses the third party plugin to add an XML file with your own code into.
