How to get access to the local.registerplugin function   [SOLVED] - View the solution
Abusername
by Abusername » Tue Mar 13, 2018 3:56 pm
When you make a krpano plugin for vanilla krpano, you have the option to get values from the local.registerplugin function. Specifically the following values: krpanointerface, pluginpath, pluginobject.
These would be very useful for me since I'm not sure I can get the WebGL canvas object without them. Does anyone know where in the Panotours pipeline the registerplugin function is ran. Or is there another way to get the same functionality?
Abusername
Re: How to get access to the local.registerplugin function
by Abusername » Fri Mar 16, 2018 1:35 pm
Maybe someone can point me to the documentation on how to get access to these values. Assuming such documentation exists. I think it would be helpful if there was a unminified version of KolorTools.js. I surmise the functions for registering plugins is actually there.
by benji33 » Fri Mar 16, 2018 3:51 pm
Our JS plugins doesn't use the krpano plugin interface.
Have a look on this documentation to see how to create a Panotour JS plugin :
http://www.kolor.com/wiki-en/action/view/My_first_plugin_(Javascript)
The file used to register/remove plugins is KolorBootstrap.js.
Abusername
by Abusername » Fri Mar 16, 2018 3:54 pm
I have created a Panotour plugin and it works great. I just need to get the WebGL canvas and context objects. I would be very grateful if anyone can offer assistance on this front.
Abusername
by Abusername » Mon Mar 19, 2018 3:04 pm
I have contacted the author of Krpano and he apparently doesn't know how Panotours implemented this. I have also looked at the build in library files and have goten an object called krpanoJS. Yet I cannnot find the WebGL object from it.
Abusername
by Abusername » Wed Mar 21, 2018 12:50 pm
Maybe I can create my own functions for these basic Krpano features. Can someone at Kolor help?
by benji33 » Thu Mar 22, 2018 4:30 pm
If you need to access the krpano player from JavaScript you can call the getCurrentTourPlayer() function.
You'll have access to the krpano player.
I've made a Panotour plugin called testWebGL must be installed into the plugins and tools directories of the Panotour User directory.
Try it, it allows you to use the krpano.webGL properities of a krpano plugin.
Perhaps this could be working for you.
testWebGL.zip
(2.23 KiB) Downloaded 20 times
Abusername
by Abusername » Tue Mar 27, 2018 10:38 am
Thank you very much.
