Help with installing Move To Custom View plugin
ijarboe
by ijarboe » Sun Mar 04, 2018 7:46 pm
Hi everyone I feel like this is a stupid question but I am trying to install the move to custom view transition thing on my tour. I'm also trying to add the call custom kr-pano code in it as well. They both seem a little bit more difficult to install than the regular plugins.
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
Re: Help with installing Move To Custom View plugin
by Cliquetsy » Mon Mar 05, 2018 2:16 pm
Well they're not plugins, one is an action and the other is a transition. So did you place the files in the right folders? And look for them in the right place in PTP after relaunching it? =)
ijarboe
by ijarboe » Mon Mar 05, 2018 8:52 pm
I think I put them in the right place. Where would I find them in the program? Right now I'm looking under the action parameters.
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Tue Mar 06, 2018 1:30 am
You'll find the call krpano code in the the advanced part of the plugin/hotspot actions.
For the transition you'll find it if you select a button or spot that has the move to xxx action, in the target transition dropdown menu.
