Combo box design missing in 2.5.9
Toni Fong
Likes: 4 posts
by Toni Fong » Mon Feb 26, 2018 3:26 pm
I'm working in a huge project with around 50 virtual tours for the same company. Some of them was already delivered.
Then I've upgraded to version 2.5.9 and the design of combo box plugin that was used in 2.5.8 is missing, there are new options, but not the old one.
Please you should take in consideration maintain old designs of some plugins when releasing new versions.
A lot of people are working on projects with designs already approved by clients and then you suddenly change and delete a design from plugin. And actually the old design of combo box is more beautiful than the new ones.
How can I found old instalation files. Another user sent me a link but there was just standard version.
I need 2.5.8 PRO for Mac. Can you help me ?
Thank you
left image is old design (the best), right is the new.
Toni Fong
Likes: 4 posts
Re: Combo box design missing in 2.5.9
by Toni Fong » Mon Feb 26, 2018 3:32 pm
A gentleman from facebook group just sent me a link for older versions: http://download.kolor.com/ptp/stable/history
Is it possible to install old design on version 2.5.9 ?
Thank you
Likes: 14 posts
by bdd » Mon Feb 26, 2018 4:23 pm
2.5.8 and 2.5.9 can't be installed at same time.
If you install the 2.5.8 version it will override the 2.5.9 .
But yes you can do it.
Toni Fong
Likes: 4 posts
by Toni Fong » Thu Mar 01, 2018 5:36 pm
Hi Gerald, thanks for reply, but my question was if it was possible to move some files and install the old design of combo box in the new version. Or maybe in the next release get it back. Why they removed the old design that was really nice ?
But yes it's possible to install both versions at same time, I just renamed one of them prior to installing the new one.
Toni
benji33 likes this post.
