Panotour Pro Crash on build
Thomocheerio
by Thomocheerio » Tue Feb 20, 2018 9:39 pm
Hi there -
Panotour pro keeps crashing when I build my tour.
Any ideas? I have uploaded the crash report to the Kolo server.
Cheers
Thom
Likes: 14 posts
Re: Panotour Pro Crash on build
by bdd » Wed Feb 21, 2018 4:20 pm
Thom,
Sadly the crash reports you sent gives only one information. It crashes while doing an infinite loop "somewhere".
1/ How many scenes do you have in this project ?
2/ How many spots do you have in this project ?
3/ How many plugins do you have in this project ?
Thomocheerio
by Thomocheerio » Wed Feb 21, 2018 5:03 pm
Hi Gerald,
Thanks for the reply,
I don't have the figures for the tour when it crashes. When I select the build tab, the program crashes.
I suspected the program was crashing because of the large number of scenes, so I started deleting to see if the program would stabilize. This has worked and the figures are as follows
1/ 1315 Scenes
2/ 4566 Spots
3/ 5 Plugins
My understanding was the program could handle any number of panoramas. What was impressive, when I did delete about 50 -70 panoramas and re-built the project from scratch. The program did manage the build without any issues. It did take a long time, but it didn't crash. I suspect the maximum panoramas the software can handle is 1400 images. On my computer.
Looking forward to hearing your thoughts.
All the best
Thom
Likes: 14 posts
by bdd » Wed Feb 21, 2018 5:24 pm
Hi Thom,
If the crash occurs when you hit the Build tab and not when you hit the Build button, then it means that the issue comes from the "Summary" display in the tab .
Can you send us your project file ? the kpt file only.
If it is the summary that causes the crash, to have your project will help us to find which part of the summary has this issue.
You can send it to contact@kolor.com and tell in the mail that it is for me.
Thomocheerio
by Thomocheerio » Wed Feb 21, 2018 5:33 pm
Hi Gerald,
I just sent you the file. To confirm the program crashes in both instances. Shortly after I click the build icon and shortly after I go to the build tab.
Cheers
Thom
edgar_ali
Liked in: 3 posts
by edgar_ali » Fri Feb 23, 2018 9:01 pm
Im having similar issues...
It crash in the middle of the building process...after the building has commence
it is also crashing when loading the panoramas (when opening the file)
in my case..this would be the latest tour im having the issue with:
2 group(s)
6 scene(s)
1 full spherical panorama(s)
1 partial spherical panorama(s)
4 planar panorama(s)
119 spot(s)
117 point spot(s)
2 map spot(s)
37 link(s)
10 link on scenes or groups
