Devices. ’videourl’ editing for Video Spot wt Firefox?   [SOLVED] - View the solution
Julien
Likes: 15 posts
by Julien » Wed Feb 14, 2018 2:33 pm
Hello all,
I’m struggling to display an Video Spot using Firefox on a device...
I’ve found this SOLVED post, dating from 2016. http://www.kolor.com/forum/viewtopic.ph ... ox#p188683
I tried it out but no success.
Is there anyone who knows, if since the last version of PTP the edition of ‘videourl’ have changed?
Here my edited lines if needed
<hotspot name="spotvideo12" videourl="%FIRSTXML%/spots/video-angkor.mp4|%FIRSTXML%/spots/video-angkor.webm|%FIRSTXML%/spots/video-angkor.ogv" devices="desktop" onunsupported="trace('not supported');" />
<hotspot name="spotvideo12" videourl="%FIRSTXML%/spots/video-angkor.mp4|%FIRSTXML%/spots/video-angkor.webm|%FIRSTXML%/spots/video-angkor.ogv" devices="tablet.or.mobile" onunsupported="trace('not supported');" />
Julien
PTP 2.5.9
Panotour Pro v2.5.7
Macbook Pro OSX 10.10.5 Yosemite
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
Re: Devices. ’videourl’ editing for hotspot video wt Firefox
by 360-compunics-com-ni » Wed Feb 14, 2018 5:03 pm
As the two lines you posted are identical there is no different setting related to the device type, so what are you trying to achieve, and how does it not work the way you expect? Sorry, i can't read the other post as it is in french.. :)
Julien
Likes: 15 posts
Re: Devices. ’videourl’ editing for Video Spot wt Firefox?
by Julien » Thu Feb 15, 2018 6:19 am
Bonjour Michael.. :)
I'm expecting to display a Video Spot (see the screen shot) with devices using different browsers.
So fare, my main video file .mp4 works with Chrome, Opera, Samsung and not with Firefox.
I’ve found several topics on the forum about the ’Alternative Files’ for videos embedding, but these topics seem to be relevant for a Video Scene and not for a Video Spot…?
This SOLVED post in French, highlights that for a Video Spot (with the browser's best compatibility...) it must be:
- Three video formats (mp4, webm, ogv) for a same video - extra two files to be added to the ‘spots’ folder after the project have been uploaded.
- The editing of MY-TOUR.xml as follows:
Re: hotspot video - compatibilité Firefox, Internet Explorer [RESOLU]
par bdd » Jeu Sep 22, 2016 2:38 pm
Change your code line
videourl="%FIRSTXML%/spots/MY_VIDEO.webm"
TO
videourl="%FIRSTXML%/spots/MY_VIDEO.mp4|%FIRSTXML%/spots/MY_VIDEO.webm|%FIRSTXML%/spots/MY_VIDEO.ogv"
I've tried this out (cf. my coded lines from my original post) and the Video Spot still do not work with Firefox. This SOLVED post is dating from 2016.. so I'm wondering if since the last PTP update, this method is still the right one?
Infos:
- My three video files are saved in 500/280.
- The .ogv and .webm video files have been trans-coded by default using the recommended http://www.online-convert.com
- Instead of getting the video to be displayed, I see the picture of the video thumbnail.
- If I open my .ogv and .webm video files with Firefox, the videos do displaying.
I’m not too sure what I’m doing wrong…
Here my test page if needed: https://www.360production.asia/360-virt ... it/video-3
Thanks,
Julien
Panotour Pro v2.5.7
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Thu Feb 15, 2018 11:35 pm
Hi Julien,
the video spot in your demotour works for me using Firefox (58.0.1 64-Bit on Linux) the same way it does with Chromium, in both cases i manually have to start it, but that's probably because you have set it to "pause on start", i guess. So maybe there is a version or platform related problem that i am not aware of.
Best wishes,
Michael
Julien
Likes: 15 posts
by Julien » Fri Feb 16, 2018 3:44 am
The issue is related using an Android or iOS device with Firefox browser, the video spot works fine on my laptop too.
Any tips?
Thank you,
Julien
Panotour Pro v2.5.7
by benji33 » Fri Feb 23, 2018 3:12 pm
Issue is only on Firefox ?
If yes, there is an issue into Firefox which can render a black tile for the video spots and livepanos.
I'll have a look ASAP.
Julien
Likes: 15 posts
by Julien » Sat Feb 24, 2018 2:07 am
Hello Benji, as fare as I've seen with my Android.. only with Firefox using video spots - mp4 (I don't use livepanos)
Still with my Android, a video spot works fine with Opera, Samsung browser and Chrome of course.
I found a similar and SOLVED topic on the forum. Your Kolor colleague -bdd- previously mentioned, the editing of the 'videourl' found into MYVISIT.xml. Find it here (french) viewtopic.php?f=94&t=33375&p=188683&hilit=video+firefox#p188683
I've tried it out but it's still don't work. I don't know if I did something wrong (I can read french), if that because of a PTP update (solved post dating from 2016), or is it something else?
Thanks for your support
Panotour Pro v2.5.7
Julien
Likes: 15 posts
by Julien » Sat Mar 17, 2018 5:05 am
Hello Benjo,
Any update on this issue?
Julien
Panotour Pro v2.5.7
by benji33 » Thu Mar 22, 2018 10:34 am
Sorry for the delay. Ican't reproduce your issue, is it possible to better describe it please? What happens in your case?
Is it also possible to send me a zipped project with the issue on FF Android + iOS to be able to see what happens?
(Send me a private message and I'll give you my email address for a https://wetransfer.com usage.)
Julien
Likes: 15 posts
by Julien » Thu Mar 22, 2018 11:21 am
Hey, have a look here https://www.360production.asia/360-virt ... it/video-1
Using FF on my Android, that video spot is not displaying and standing by its thumbnail.
Thumbnail found in MYVISISTdata/spots
Looking for your email to forward you the project.
Panotour Pro v2.5.7
Re: Devices. ’videourl’ editing for Video Spot wt Firefox?  [SOLVED]
by benji33 » Thu Mar 22, 2018 5:29 pm
OK sorry seems to be linked to a Firefox issue. I've no issue with the latest FF 59.0.1 version but until 58.0.2 version the bug was present.
Try to update your FF version if possible on your Android device.
Julien
Likes: 15 posts
by Julien » Mon Mar 26, 2018 1:14 pm
Yeah, you are right! Easy & simple... Good :)
Panotour Pro v2.5.7
