Map hotspot   [SOLVED] - View the solution
edgar_ali
Liked in: 3 posts
Map hotspot
by edgar_ali » Thu Feb 08, 2018 5:52 am
Im having troubles with the map..
When i click on the map symbol, this does not take me straight to the panorama...
Am i doing something wrong?
The following clip shows my issue:
https://www.dropbox.com/s/45bade3gdc1inw8/map.mp4?dl=0
This is my configuration of the map hotspot:
https://www.dropbox.com/s/mda6pctsce56t ... e.JPG?dl=0
Anyone can help???
Re: Map hotspot
by Annis » Thu Feb 08, 2018 10:57 am
Well your map is fullscreened, and in your video you click on the spot but you didn't close the map. So what scene is there behind the map after clicking on the spot?
edgar_ali
Liked in: 3 posts
Re: Map hotspot  [SOLVED]
by edgar_ali » Fri Feb 09, 2018 12:22 am
Annis:
You are absolute right...I just realised that the scene is changing when clicking on the hotspot...also realised that if I go to the advance features of the hotspot and click "close on ne pano" the map will close as soon as i click on the hotspot...
Im just wondering now....in the video when i click on the hotspot it display a message (which is the name of the panorama).. How can i replicate that again...since i modified the hotspot, I am moving into the new panorama and im not able to see the comment...however what i would like to see in the comments instead of the name of the file, might be the name of the place instead...is it possible to do that?
