Button to toggle Floorplan   [SOLVED] - View the solution
mykill
Likes: 4 posts
by mykill » Tue Feb 06, 2018 3:14 pm
Dear Forum,
in my application I want to have a floorplan that slides in and out from the left side of the screen. To do so I want to use a semi-transparent button at the center of the left side of the screen. Basically it works that I use the toggle button from the controls assets. The problem that remains is that this button is hidden by the floormap itself. Is there a way to bring this button in front, so it doesn't get covered by the floormap itself?
Thanks for some hints,
best regards,
Michael
Re: Button to toggle Floorplan
by Annis » Tue Feb 06, 2018 3:31 pm
No, the floorplan is an HTML5 element which will always be in front of everything else in the tour.
http://www.kolor.com/wiki-en/action/vie ... en_defined
mykill
Likes: 4 posts
Re: Button to toggle Floorplan  [SOLVED]
by mykill » Tue Feb 06, 2018 3:34 pm
Thanks, for the reply! I just found a workaround for my issue. I made the floorplan itself click sensitive, so it hides, when I click on the plan itself.
Annis likes this post.
