CallCustomCode plugin location?   [SOLVED] - View the solution
Treto
Liked in: 7 posts
by Treto » Wed Jan 24, 2018 5:54 pm
I installed the CallCustomCode (Call KrPano Code) plugin, but can not locate it in the side bar.
Can anyone tell me where it is located?
I would like to use it to with a simple button.
I also tried adding a simple button to see if it would automatically display in "Advanced" actions, but I only see "change language" and "call javascript"
Please help.
Thank you,
Treto
Screen Shot 2018-01-24 at 8.52.11 AM.png (8.56 KiB) Viewed 428 times
Re: CallCustomCode plugin location?
by Annis » Thu Jan 25, 2018 10:32 am
It's not a plugin, it's an action. So you have to place the files in the Action folder not the Plugin folder!
You'll never find it otherwise. :)
