Best resolution for quality and performance?
S3D
by S3D » Sat Jan 20, 2018 1:07 pm
Hi, i`m having performance problems with my tours. Which is the best resolution for performance and quality, please?
Re: Best resolution for quality and performance?
by Destiny » Sun Jan 21, 2018 3:24 am
Hi.. The way PTP works, it should not make any difference.. You only load the area of image currently being viewed, since multiple folders with slices are created...
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Sun Jan 21, 2018 7:04 am
The optimum image size is 13312 x 6656. Yes it might sound strange but Panotour uses 512px tiles. Same for Google street view.
