Deep Link Groups
EbbeLiebtFlut
Deep Link Groups
by EbbeLiebtFlut » Fri Jan 19, 2018 10:01 pm
Hi, there is a possibility to select groups with deep links. I would like to create a big tour for a customer. There are several apartments that I want to retrieve separately. Is that possible ? Thank you
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
Re: Deep Link Groups
by 360-compunics-com-ni » Sat Jan 20, 2018 11:48 pm
You can select any pano as startscene using the "s=<panoid>" parameter to your tours' URL. If you want to restrict the users access to one group of panos only, you could disable the controlbars "Previous-/Next-Pano"-buttons and implement the navigation via hotspots and floorplan spots only.
There is a commercial plugin thats aids in this process, it is described here: https://www.kolor.com/forum/viewtopic.php?f=40&t=36218
Using the "GroupOnly Previous/Next Pano"-plugin you can make use of the controlbars "Previous-/Next-Pano"-buttons and restrict them to stay within the current group of panos. This aproach works with one group only, if you need one "apartment-tour" to have several panogroups, this would require additional programming.
