Pause tour load on littel planet?
Treto
Liked in: 7 posts
by Treto » Fri Jan 19, 2018 4:25 pm
Hello:
Is it possible pause a tour on load to remain in the little planet display?
I am using the StartScreen plugin, but do not see an option in the plugin settings to accomplish nor in the regular PTP settings.
Essentially, I want my tour to load as a little planet and stay as a tiny planet until the user clicks a button to enter the tour at which point the little planet effect will animate to normal view.
Thoughts?
Re: Pause tour load on littel planet?
by Annis » Fri Jan 19, 2018 4:46 pm
Hmmm... You could fake it?
Using CAOTE, set the default projection of that scene to little planet. Then with the Start Screen plugin (if you can assign several actions), give it the action of changing the projection back to your preferred projection. If you can't use Start Screen you can create a new button for that and have it hide once you've clicked on it.
