Floor Plan Operation Issue   [SOLVED] - View the solution
RockvilleBob
by RockvilleBob » Wed Jan 17, 2018 1:27 pm
I have a tour where the Floor Plan halts autorotation and it also will not appear on some scenes. Any tips on how correct what I am doing would be appreciated.
Liked in: 440 posts
Re: Floor Plan Operation Issue  [SOLVED]
by Annis » Wed Jan 17, 2018 1:44 pm
The floorplan being open pausing autoration is a feature that is checked by default, you can uncheck it in the floorplan's settings.
As for it not appeared on some scenes, is the tour online? Do you have a link?
What plugins are in your tour?
RockvilleBob
by RockvilleBob » Wed Jan 17, 2018 2:21 pm
Thank you Annis. Going through the options cleared up all the problems. The tour is not online yet. It is for the Delaware Historical Society. Panotour Pro is easy to use but I do not use it frequently and I forget some of the mechanics. Having the forum to help people like me is a big help. Thanks again for your assistance.
Annis likes this post.
