Tour panoramas not opening in default view - Panotour V2.5.9   [SOLVED] - View the solution
ianwilde
by ianwilde » Tue Jan 16, 2018 5:02 pm
I can't seem to resolve this issue, but don't recollect it being a problem previously.
Whatever default view I set in "Preview" & confirmed as set in "Default View" by clicking the "Set Default View" button in the top left of Preview window, when I view the tour either on or off line, all the panoramas open in a completely different view.
If I immediately stop autorotation & manually select another panorama from the panorama combo box or next panorama arrows, or allow the Autotour to chane panos, the same thing happens
Although the tour was constructed from a preset saved from another more complex tour, I have removed the Map & Compass plug ins & it is a very basic tour and I can't see why this is happening.
Any ideas would be appreciated.
Re: Tour panoramas not opening in default view - Panotour V2
by Annis » Wed Jan 17, 2018 11:28 am
What other plugins are in your tour? Are any "Day/night" plugins there or GArrows or the like?
Is the tour online?
ianwilde
by ianwilde » Wed Jan 17, 2018 12:55 pm
Hi Annis,
I have GArrows but the panos are not linked so they are not active on screen. It is a mailshot to a cottage hire company we used recently, so is on line, but not fo general circulation. I am trying to mimic a very basic tour used by a competitor without any pano linking.
view at:- https://s3.eu-west-2.amazonaws.com/vide ... index.html
Only the first pano seems to show as set.
I have attached a few screenshots which might help. If you want anything else,please let me know.
many thanks & appreciated.
Ian
by Annis » Wed Jan 17, 2018 1:48 pm
Could you show me your settings for GArrows? There's a setting that enables keepview so that would override your default views... Or just remove it from the tour if you're not using it?
ianwilde
by ianwilde » Wed Jan 17, 2018 2:17 pm
Hi annis,
Thanks & I think I did try unticking Keepview & it didn't seem to make any difference,however at that point I think I might have been forgetting to press the Set default view button after altering the view!
I haven't yet tried deleting the plug in. I will wait for your reply first, then try removing it, as this is a fairly new plug in & as I mentioned earlier, i don't recollect having this problem previously.
I have attached the GArrows settins, with advanced only open on what might appear relevant.
Cheers
Ian
ianwilde
by ianwilde » Wed Jan 17, 2018 2:42 pm
Annis,
I have removed GArrows & the problem is solved. I will reinstall it later to see if with Keepview unticked the problem returns. If that were to be the case, I would not know how to resolve that, but will make a new post if this one is no longer active.
Many thanks for your help!
