Using 2 Panos out of 3DApplication to VR   [SOLVED] - View the solution
PdZero
by PdZero » Tue Jan 09, 2018 12:37 pm
Hello all,
Maybe its a stupid question but I never found a solution and did not find any in the offical VR Guide on Kolor.com.
I know that you could use one 360° Panorama to generate a "faky" VR Panosolution by adding ?vr to your URL or by adding a VR Button in Panotour Pro. But Iam rendering 2 Panos with different "Eye" Distance (out of a 3Dprogram) (or better explained from two different locations and want them to be used by Panotourpro as left and right Eye. But I dont know how to set this up in Panotour Pro.
Could someone help me pls? Thank you very much!
greets!
signmaster
Likes: 52 posts
Liked in: 36 posts
Re: Using 2 Panos out of 3DApplication to VR  [SOLVED]
by signmaster » Tue Jan 09, 2018 2:28 pm
Hi PdZero
Tutorial link below, I just tried it and appeared to work well.
http://www.kolor.com/wiki-en/Panotour_-_Advanced_-_Stereoscopic_Panoramas
Steve
Annis likes this post.
PdZero
by PdZero » Tue Jan 09, 2018 4:57 pm
Thank you very much! Worked perfectly!
Users browsing this forum: No registered users and 8 guests
