what do you have to do to get a response from someone?
42VR
Likes: 13 posts
by 42VR » Sat Jan 06, 2018 3:48 pm
i can't believe i'm the only one asking about this.
i understand that PTP pro 2.5 allows you to place a regular hotspot on an imported 360 video.
but is there any way to place the hotspot at different points in the timeline of the video?
maybe a doorway at 1 minute in, then a car at 3 minutes in, then 2 hotspots at 5 minutes etc.
how do i place hotspots in a video at different times in the video?'
i can't believe they can't do this!
sort of basic for video, i would think?
am i just missing something?
i can't find any info or tutorials how to do this.
thanks,
randy
Re: what do you have to do to get a response from someone?
by Destiny » Sat Jan 06, 2018 10:08 pm
Hi.. Sorry to say, not possible.. Kolor will be around on Monday..
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Sun Jan 07, 2018 4:46 am
Well, that's a strange way to ask for help, but ok..
While it is not possible with default PTP features, you can do it using some extra actions and plugins, both available here: http://www.kolor.com/wiki-en/action/view/Panotour_-_Advanced_-_Extra_Plugins
You can use the "Show/Hide-Hotspot"-actions in combination with the "Delayed Action"-plugin to achieve the effects you are looking for, and you probably will use the "CAOTE"-plugin as well to initially hide the hotspots showing your images.
Annis likes this post.
