blank preview in High Sierra
magrittedeau
by magrittedeau » Fri Dec 15, 2017 8:48 pm
I just upgraded my OS to High Sierra (10.13.1) from Mountain Lion. Now when I try to preview (View last built tour), the trigger opens a new tab but nothing shows up/blank screen. Anyone know what is this? I am using Chrome, before it was working well.
thanks,
Re: blank preview in High Sierra
by Destiny » Fri Dec 15, 2017 9:26 pm
Hi.. I have the same setup with no issues.. Perhaps make sure you update your graphic drivers.. Not really sure why you have the issue... Try another new quick build for testing..
Annis likes this post.
by klausesser » Fri Dec 15, 2017 10:07 pm
magrittedeau wrote:Hi,
thanks,
Hi!
Did you alter the path to your images?
itsrichphoto
Likes: 8 posts
Liked in: 5 posts
by itsrichphoto » Thu Jan 04, 2018 12:18 am
If there is no error message, then it means it is probably working. Try refreshing the page and see if that works. It can take a few seconds to load sometimes. Or perhaps rebuild the project. Perhaps, even re-export with a different web page template and see if that makes a difference.
