Custom orientation not taken
Stefan1
by Stefan1 » Fri Dec 15, 2017 6:21 pm
When I create a "custom picture orientation" when linking pictures in a virtual tour, sometimes the custom orientation does not work. The virtual tour gets built with the default orientation. It only happens for some connections and not for all. What am I doing wrong?
Re: Custom orientation not take
by Annis » Mon Dec 18, 2017 3:35 pm
What do you mean by custom picture orientation? Could you please illustrate your issue?
Stefan1
Re: Custom orientation not taken
by Stefan1 » Mon Dec 18, 2017 9:15 pm
On the tour tab: When you "Add Point" to link two Panoramas, after adding such point you have to select the Panorama the point should link to on the right side. Then, on this right side, under "Go to panorama or a group" you can not only select which panorama, but also the orientation of the new panorama. The options are "Default target view" and "Custom view".
The problem:
After building the tour, sometimes the tour correctly displays the "custom view", other times it takes the "Default target view", even though a "custom view" was set. Sometimes it takes the custom view, sometimes it doesn't.
Stefan1
by Stefan1 » Fri Feb 09, 2018 12:08 am
Any solutions anyone? It keeps happening to me.
PieroA likes this post.
PieroA
Likes: 4 posts
by PieroA » Fri Jul 13, 2018 8:49 am
Same here, even if custom view is selected, it keeps showing the default orientation.
Stefan1 likes this post.
Stefan1
by Stefan1 » Fri Jul 13, 2018 5:22 pm
Still having this issue. @KolorTeam?
PieroA
Likes: 4 posts
by PieroA » Fri Jul 13, 2018 5:32 pm
Confirm
Likes: 14 posts
by bdd » Mon Jul 16, 2018 3:18 pm
Can you send us a kpt file from a project on which you reproduce this issue ?
PieroA
Likes: 4 posts
by PieroA » Mon Jul 16, 2018 3:25 pm
attached
To set the Custom view shuld be enough just to rotate the pano orientation, correct? or there is a particular sequence of actions to make the orientation being saved?
PardgroupDemoBaobab1.kpt
(128.89 KiB) Downloaded 68 times
Likes: 14 posts
by bdd » Tue Jul 17, 2018 12:31 pm
The "orientation" is saved, but you changed the default target transition of the spot style to "Load panorama view".
Restore the default transition which is : "Load custom view"
PieroA
Likes: 4 posts
by PieroA » Tue Jul 17, 2018 2:15 pm
Thank you for your precious suggestion, it solved my issue.
