Add spacing/padding to classic control bar buttons?   [SOLVED] - View the solution
Treto
Liked in: 7 posts
by Treto » Thu Nov 23, 2017 1:53 am
Hello:
Anyone know how to add spacing/padding between the Classic Control Bar buttons?
I duplicated the plugin and renamed it, but can not figure out how to add some space/padding between the buttons.
Thank you.
Re: Add spacing/padding to classic control bar buttons?  [SOLVED]
by Annis » Fri Nov 24, 2017 1:51 pm
Well I had to do some testing (which you could have done ;) )... Try this:
In the .tmpl file look for {% with button_width as button_offset %} and replace button_width with the pixel amount.
For example, {% with 50 as button_offset %}
Treto
Liked in: 7 posts
by Treto » Fri Nov 24, 2017 6:39 pm
Hi Annis:
Thanks for responding. Unlike a lot of users, I actually do testing before I post. :)
I had tried adjusting the pixel amounts in the tmpl file for button width, offset and background width on lines 8, 9 & 10, but no luck.
I missed the "button_width" on line 52.
I also tried adjusting the size of the icon files themselves.
You solution works. Thanks again.
Annis likes this post.
